Ana içeriğe geç
Samsung Galaxy Tab A 10.1 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 2, 2 resimden 2.
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Disconnecting the battery: adım 3, 1 resimden 1.
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 5, 3 resimden 3.
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Battery removal: adım 6, 2 resimden 1. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Battery removal: adım 6, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Samsung Galaxy Tab A 10.1 Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
    • Slide the orange ribbon cables out of the ZIF connectors.
    • Remove the front-facing camera.
  8. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the headphone jack from the motherboard.
    • Use a Phillips # 000 to remove six 4mm screws.
  9. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 9, 2 resimden 1. Samsung Galaxy Tab A 10.1 Motherboard Replacement: adım 9, 2 resimden 2.
    • Lodge the plastic opening tool under and lift the motherboard out of the tablet.
    • Be careful not to snag any connectors.
    • Remove the metal bracket that was underneath the charging port and set aside.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Isabella Li
2.364 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G6
4 Üyeler
26 adet Kılavuz yazıldı
Bir Yorum
habe es geschafft zum zerlegen... leider ist nur der verschluss vom LCD hops gegangen. Ohne diesen geht wohl nix. Kein Bild.
Mike Muley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 51
Son 30 gün: 140
Her zaman: 16,296
