Ana içeriğe geç
Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 2, 3 resimden 3.
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 3, 3 resimden 3.
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: adım 4, 3 resimden 1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: adım 4, 3 resimden 2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: adım 4, 3 resimden 3.
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
    • Use the plastic opening tool to remove the motherboard from the case.
  5. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while prying upwards until the screen separates from the bezel.
    • The screen may crack during this process so be wary of broken glass.
    • Applying heat may be necessary to loosen the glue.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Guneet Bawa
688 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018 üyesi
UWT-LINER-S18S1G5
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 3,354
