Ana içeriğe geç
Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: adım 1, 1 resimden 1.
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 2, 2 resimden 2.
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 3, 3 resimden 3.
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 5, 3 resimden 3.
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: adım 6, 1 resimden 1.
    • Remove the auxiliary port from the case.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bradley Watson
1.079 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Passmore Spring 2017 USF Tampa, Team 5-4, Passmore Spring 2017 üyesi
USFT-PASSMORE-S17S5G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 59
Her zaman: 3,997
