Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your device is unable to receive any sort of power or charge, there could be dirt or other debris stuck in the charging port that can permanently damage the charging port. This could prevent the device from charging properly. This guide will outline how to properly remove the charging port without damaging other parts of the device.
  1. Insert a metal spudger between the back case and the screen of the device.
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Remove the two 2.8 mm Phillips #000 screws from the speakers. Remove the two 2.8 mm Phillips #000 screws from the speakers.
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Each speaker is now only connected to the main device by small plastic snaps.
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
  4. Remove the four  2.8mm #000 Phillips screws that hold the charging port and headphone jack in place. Remove the four  2.8mm #000 Phillips screws that hold the charging port and headphone jack in place. Remove the four  2.8mm #000 Phillips screws that hold the charging port and headphone jack in place.
    • Remove the four 2.8mm #000 Phillips screws that hold the charging port and headphone jack in place.
  5. Disconnect the green square connector from the motherboard. To do so, put the flat end of the plastic opening tool underneath the connector and push down.
    • Disconnect the green square connector from the motherboard. To do so, put the flat end of the plastic opening tool underneath the connector and push down.
    • During reassembly, two clicks signify the charging board is completely attached to the motherboard.
  6. Place the heavy duty spudger underneath the charging port and push down to remove the charging port.
    • Place the heavy duty spudger underneath the charging port and push down to remove the charging port.
    • To reinsert the charging port, angle the port downwards towards the battery. Then press down the outside edge of the charging port.
  7. Peel the charging assembly from the device to completely remove the charging port from the device.
    • Peel the charging assembly from the device to completely remove the charging port from the device.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Paulina Nguyen
900 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team S1-G3, Livingston Spring 2017 Cal Poly, Team S1-G3, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S1G3
1 Üye
12 adet Kılavuz yazıldı
9 Yorum
Note that you have to transfer the shroud over the charge port from the old assembly to the new one, if the replacement part wasn’t supplied with it. This threw me when I was screwing the new unit in, until I inspected the old part more closely. Also, it takes a lot more effort than you would expect to undo the case in the first place!
Lee Cooke - Yanıt
How did you glue it on to the new board? Which glue did you use
swordart -
Taking the cover off wasn’t the easiest, but after that it went really smooth. Thanks for the instructions! It really helped a lot! Got my tablet charging again, so I am satisfied!
Brandon Congdon - Yanıt
there was a tape glued to right part of charging assembly and also part under the right speaker. is it a conductive tape, should it be replaced ? because once peeled off old assembly part, its difficult to put it back on the new one..
Anthony Ménagé - Yanıt
Are the instructions the same for the SM-P550?
R T - Yanıt
Great tutorial. Fixed my Tab. If you have the 9.7 w/pen there’s one extra connection on the charging assembly next to the speaker that you have to unplug before you peel out the assembly.
R T - Yanıt
Did you reconnect this piece to the replacement part? I dont see how it can be reattached
Stacey Cerminaro -
Can someone tell me about what kind of a glue I need to put the shroud on the new
swordart - Yanıt
great tutorial!
I’m trying to repair my motherboard and to do so i must replace a component which is burnt… can you please help me to find out what component is?
This is a picture of the component.
<a href="https://ibb.co/mHQ0k5D"><img src="https://i.ibb.co/SKqcbws/Inked-IMG-20191... alt="Inked-IMG-20191110-204740-LI" border="0"></a>
Thank you!
Vincenzo Difino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 46
Son 30 gün: 224
Her zaman: 20,756
