Ana içeriğe geç
Samsung Galaxy Tab A 9.7 Display Digitizer Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 9.7 Display Digitizer Replacement, Display Glass: adım 1, 1 resimden 1.
    • Microwave the iOpener for 30 seconds.
    • Place the iOpener on each side of the screen for 30 seconds.
  2. Samsung Galaxy Tab A 9.7 Display Digitizer Replacement: adım 2, 1 resimden 1.
    • Take a metal spudger and wedge it between the screen and the glass.
    • Avoiding the screen itself, run the spudger along the perimeter of the device to weaken the glue between the glass and screen, and pry the glass off.
  3. Samsung Galaxy Tab A 9.7 Display Digitizer Replacement: adım 3, 1 resimden 1.
    • Using a suction cup, gently remove the screen from the device.
    • When placing a new screen on the device, remember that you will have to reapply adhesive to the outside of the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Paulina Nguyen
982 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, Livingston Spring 2017 Cal Poly, Team S1-G3, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S1G3
1 Üye
12 adet Kılavuz yazıldı
4 Yorum
This is not entirely correct. For the proper way to replaced this glass, you need to remove the back cover as well, in order to connect the digitizer flex cable to the board.
Hank - Yanıt
incomplete.
Niah Mason - Yanıt
Not a good tutorial.
Easy Repair - Yanıt
The following steps are completely missing:
- remove the backcover with a pick or Spudger running between back cover and body.
- flip up the lock for the flex cable with a spudger
- slide the flex cable through the body and remove the display
- slide the flex cable of a new display throught the body to the backside
- connect the flex cable to the connector (be aware of correct aligning) and flip down the lock
- glue the display back to the body (do not use much pressure as it may crack the new display!)
- clip back on the back cover
BenZ78 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 3,723
