Ana içeriğe geç
Samsung Galaxy Tab A 9.7 Display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 9.7 Display Replacement, Back Cover: adım 1, 1 resimden 1.
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Display Replacement, Battery: adım 2, 2 resimden 1. Samsung Galaxy Tab A 9.7 Display Replacement, Battery: adım 2, 2 resimden 2.
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7 Display Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab A 9.7 Display Replacement: adım 3, 2 resimden 2.
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7 Display Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab A 9.7 Display Replacement: adım 4, 2 resimden 2.
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7 Display Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab A 9.7 Display Replacement: adım 5, 2 resimden 2.
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
  6. Samsung Galaxy Tab A 9.7 Display Replacement, Display: adım 6, 1 resimden 1.
    • Gently remove the tape covering the screen ribbon cable, located at the top of the devise.
    • With the plastic spudger, disconnect the ribbon cable from the motherboard, located at the middle of the device.
  7. Samsung Galaxy Tab A 9.7 Display Replacement: adım 7, 1 resimden 1.
    • Using a plastic spudger, work around the edge of the screen, prying the screen away from the device.
  8. Samsung Galaxy Tab A 9.7 Display Replacement: adım 8, 1 resimden 1.
    • Use the left side of the tablet as a hinge to swing the display assembly open.
    • As you move the display assembly, make sure that the display ribbon cable is unattached.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
my device burnt down.
HetBesteNaam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 64
Her zaman: 2,711
