Ana içeriğe geç
Samsung Galaxy Tab A 9.7 Speakers Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Back Cover: adım 1, 1 resimden 1.
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: adım 2, 2 resimden 1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: adım 2, 2 resimden 2.
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Speakers Replacement: adım 3, 1 resimden 1.
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
Sonuç
Paulina Nguyen
982 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, Livingston Spring 2017 Cal Poly, Team S1-G3, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S1G3
1 Üye
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 1,482
