Ana içeriğe geç
Samsung Galaxy Tab A Earphone Jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A Earphone Jack Replacement, Earphone Jack: adım 1, 1 resimden 1.
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
  2. Samsung Galaxy Tab A Earphone Jack Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab A Earphone Jack Replacement: adım 2, 2 resimden 2.
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Earphone Jack Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab A Earphone Jack Replacement: adım 3, 2 resimden 2.
    • Use the spudger to disconnect the earphone jack from the motherboard.
    • To prevent any damage to either the earphone jack or motherboard, it is recommend to remove the jack at its blue rubber portion.
    • The connected and disconnected earphone jack is shown in the first and second picture, respectively.
  4. Samsung Galaxy Tab A Earphone Jack Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab A Earphone Jack Replacement: adım 4, 2 resimden 2.
    • Use the PH0 screwdriver bit to remove the 2.5 mm screws attaching earphone jack to the rest of the device.
    • The second picture shows this process in action.
  5. Samsung Galaxy Tab A Earphone Jack Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab A Earphone Jack Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab A Earphone Jack Replacement: adım 5, 3 resimden 3.
    • Use the spudger to fully remove the earphone jack from the rest of the device.
    • The second picture shows what the device should look like once the earphone jack has been removed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Wozny
3.690 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-4, Blackwell Winter 2016 USF Tampa, Team 17-4, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G4
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 5,204
