Giriş
The front camera of the Samsung Galaxy Tab E 8.0 can be damaged if the camera is struck by a hard object. This guide shows how to replace the tablet's front camera which is attached to the motherboard.
Parçalar
Hiçbir parçaya gerek yok.
  1. Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen. Make sure the device is off and the SD card is removed before taking off the back casing.
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Use the tweezers to lift the switch connecting the front camera to the motherboard. Remove the front camera from the motherboard by lifting with the tweezers. Remove the front camera from the motherboard by lifting with the tweezers.
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
Sonuç
Chrissy B
717 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team S13-G4, White Fall 2018 Cal Poly, Team S13-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S13G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 51
