Ana içeriğe geç
Samsung Galaxy Tab E 8.0 Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: adım 2, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to lift the switch connecting the back camera to the motherboard.
    • Use your hand to remove the back camera from the motherboard.
  3. Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: adım 3, 3 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: adım 3, 3 resimden 2. Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: adım 3, 3 resimden 3.
    Satın Al
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
  4. Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: adım 4, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: adım 4, 2 resimden 2.
    Satın Al
    • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
    • Release the strap from the switch by lifting the strap with your hand.
  5. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 5, 2 resimden 2.
    • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
    • Lift the top end of the strap with your hand and remove the strap completely from the device.
  6. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 6, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 6, 2 resimden 2.
    • Use the tweezers to flip the switch of the connector.
    • Lift the connector from the motherboard.
    • This connector does not come completely off, but disconnects from the motherboard.
  7. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 7, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 7, 2 resimden 2.
    • Use the tweezers to flip the switch of the blue connector on the motherboard.
    • This switch can detach from the device, but just needs to disconnect from the motherboard.
    • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
  8. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 8, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 8, 2 resimden 2.
    • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
  9. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 9, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 9, 2 resimden 2.
    • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
    • Lift the motherboard with your hand to detach the motherboard from the device.
  10. Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: adım 10, 3 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: adım 10, 3 resimden 2. Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: adım 10, 3 resimden 3.
    Satın Al
    • Use the tweezers to lift the flap on the left end of the battery and pull up with your hand to remove the battery.
    • The battery is held by an adhesive on the back, so it will take some force to remove.
  11. Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: adım 11, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: adım 11, 2 resimden 2.
    • Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
    • Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
    • The metal spudger may be needed to get between the screen.
    • The metal spudger may cause more damage to the screen if used with force.
  12. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 12, 2 resimden 1. Samsung Galaxy Tab E 8.0 Screen Replacement: adım 12, 2 resimden 2.
    • Use the metal spudger to get between the device and the internal screen.
    • Pry out the screen from the device.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Christian Bloemhof
1.102 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G4, White Fall 2018 Cal Poly, Team S13-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S13G4
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
I am working on a 7” lite E. Is the procedure about the same?
George Tedrick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 58
Her zaman: 9,079
