Ana içeriğe geç
Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Back Casing: adım 1, 1 resimden 1.
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 3, 3 resimden 3.
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: adım 4, 2 resimden 1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Locate the speaker in the top right corner of the back casing. Use a pair of tweezers to pull peel up the film connecting the speaker to the case.
  5. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: adım 5, 2 resimden 2.
    • Once you've detached the film connecting the speaker to the case, use the tweezers to remove the speaker completely.
Sonuç
Dave Dorzback
626 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G4
3 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
Then what? How does this fix the problem? Can I tweek the speaker? Do I buy a new, more powerful speaker? What is your point in this post?
Janet - Yanıt
@Janet Sorry I know you probably wont even see this, but its to help those who wish to replace a broken speaker, its not about implanting a 9” subwoofer. Sorry but sometimes the simplest of explanations will often answer your questions.
sannas30 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,332
