Giriş
Before you can access any internal components you'll need to open the tablet up. This prerequisite guide will walk you through the process. This is easily the most frustrating part of any repairs or replacements to this tablet. It's going to take some muscle to get it open, but as long as you're using the correct plastic opening tools there is little risk of breaking the tablet.
Neye ihtiyacın var
Insert one of the blue plastic opening tools between the glass display and the edge of the tablet's outer shell to break the seal around the display. It doesn't matter where you start the process, but once you form a gap, continue opening the gap around the edge of the device.
The display assembly and back casing should gently come apart after a gap is formed around the perimeter.
