Giriş
This guide is a multi-step process to replace the camera on your Samsung tablet. In order to replace the camera, you will need various tools specific to working with tablets and smartphones. In our guide you will find the specific tools we used to complete the replacement of the camera. This repair is needed if you can no longer take a picture with your tablet due to a camera malfunction internally or if the lens cracked from hitting a hard surface. One step to be cautious on when replacing the camera is removing the digitizer from the LCD screen. The digitizer is connected to the circuit board by ribbon cables, so it is very important to peel back the digitizer slowly and carefully to not rip or tear the cables. The other steps should also be done with care but do not pose as much of a threat from the mistake category.
Neye ihtiyacın var
Place the Tablet on a flat surface
Gather the required tools: iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
2 farklı kişi bu kılavuzu tamamladı.
