Ana içeriğe geç
Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement, Camera Replacement: adım 1, 2 resimden 1. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement, Camera Replacement: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Place the Tablet on a flat surface
    • Gather the required tools: iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
  2. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 2, 1 resimden 1.
    • Place suction handle in the center of the screen. Firmly press it downwards.
    • This is done to help assist lifting the screen once the edges are loose.
  3. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 3, 1 resimden 1.
    • Grab the iFixit opening tool and wedge the sharp end into the corner of the screen. Pry it upwards, lifting up the corner of the screen.
  4. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 4, 1 resimden 1.
    • Place the iFixit opening pick between the lifted corner and the housing to prevent the screen from falling back into the housing.
  5. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 5, 1 resimden 1.
    • Continue around the perimeter of the screen until you have placed the picks in each remaining corner.
    • Be careful removing the double-sided tape while lifting the screen so that the screen does not break.
  6. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 6, 1 resimden 1.
    • Grab the suction handle and gently lift the screen towards the top of the tablet.
    • Take care while lifting the screen to avoid damaging the ribbon cable at the top of the tablet.
  7. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 7, 1 resimden 1.
    • Place the removed screen that is still attached to the ribbon cable flat on the table.
  8. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 8, 1 resimden 1.
    • Grab the iFixit opening tool and wedge the sharp end into the corner of the housing and pry upwards.
    • Place an iFixit opening pick between the housing and the LCD assembly.
  9. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 9, 1 resimden 1.
    • Continue along the outer edge of the housing until you have placed an iFixit opening pick in each corner.
  10. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 10, 1 resimden 1.
    • Remove the LCD assembly from the housing and place it face down on the table.
  11. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 11, 1 resimden 1.
    • Locate the ribbon cable connector on the back of the LCD assembly.
    • Use the spudger to pry the ZIF connector lock tab upwards.
    • Pull the the ribbon cable to remove it from the connector.
  12. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 12, 1 resimden 1.
    • Use the curved precision tweezers and carefully peel off the protective green film on top of the camera connector.
  13. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 13, 1 resimden 1.
    • Use the spudger and gently pry the ZIF connector lock tab upwards, releasing the ribbon cable.
  14. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: adım 14, 1 resimden 1.
    • Grab the camera and pull up and away from the connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Skoog
250 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Summer 2019 IUPUI, Team S4-G4, Wilson Summer 2019 üyesi
IUPUI-WILSON-SU19S4G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 526
