Ana içeriğe geç
Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: adım 1, 3 resimden 3.
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 2, 2 resimden 2.
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 7, 1 resimden 1.
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nicholas Nolan
805 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G2, Hoffman Spring 2017 USF Tampa, Team S19-G2, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,045
