Ana içeriğe geç
Samsung Galaxy Tab Pro 8.4 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab Pro 8.4 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Battery Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab Pro 8.4 Battery Replacement: adım 2, 2 resimden 2.
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Battery Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab Pro 8.4 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Battery Replacement: adım 4, 1 resimden 1.
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Battery Replacement: adım 5, 1 resimden 1.
    • The battery should be completely disconnected and the new one can be installed.
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Jonathan Romine
1.072 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G2
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Samsung Galaxy tab ki battery 4800 mah
Razwan good ashqui - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 12,178
