Ana içeriğe geç
Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 2, 2 resimden 2.
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 3, 2 resimden 2.
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 4, 1 resimden 1.
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 5, 1 resimden 1.
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: adım 6, 2 resimden 1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: adım 6, 2 resimden 2.
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: adım 7, 3 resimden 3.
    • Gently pull up on tab that connects the charging port to the motherboard
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jonathan Romine
1.072 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G2
4 Üyeler
10 adet Kılavuz yazıldı
3 Yorum
Thank you for your help. You are awesome :-)
Kim Williams - Yanıt
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - Yanıt
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 4,060
