Neye ihtiyacın var
Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
5 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thank you for your help. You are awesome :-)
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
