Ana içeriğe geç
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 2, 2 resimden 2.
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 4, 1 resimden 1.
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 5, 1 resimden 1.
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 7, 3 resimden 3.
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: adım 8, 3 resimden 3.
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
victor johnson
242 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 2,393
