Ana içeriğe geç
Samsung Galaxy Tab S 8.4 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S 8.4 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Samsung Galaxy Tab S 8.4 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Battery Replacement: adım 2, 1 resimden 1.
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Battery Replacement, Battery: adım 4, 2 resimden 1. Samsung Galaxy Tab S 8.4 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • The battery is glued down, usually with double-sided tape along the sides. The goal is to lift the battery out by pulling on the folded white tab in the top right corner. It may be necessary to first loosen the adhesive by running a flat, thin plastic tool under the edges of the battery.
    • Be careful when lifting the battery out, it is still connected to the device.
  5. Samsung Galaxy Tab S 8.4 Battery Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab S 8.4 Battery Replacement: adım 5, 2 resimden 2.
    • Gently grasp and lift up the light green connector located near the bottom left corner of the battery. It is connected to the battery by red, green, and black wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
Sonuç
65 farklı kişi bu kılavuzu tamamladı.
Tara Fussell
984 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G15
4 Üyeler
12 adet Kılavuz yazıldı
11 Yorum
Nice and simple instructions...now, can you do one to show replacement of LCD and screen?:) Thanks! Vicki.
Vicki - Yanıt
Mine, the T320, the battery was held in place by 4 screws. Otherwise same steps.
The cover was tricky to get off, the plastic bends a bit but it took some careful force.
James Thrun - Yanıt
Thanks , Easy to understand and perform. I think the battery connector is loose from mother board. How do I fix that?
SE Simon - Yanıt
I'm sure it's a solder job to reattach the connector to the motherboard. From the picture above it looks like a PIH connector but it may be an SMT, hard to tell without physically seeing it close up. At any rate, being this is a newer device, the solder used is lead free (RoHS compliant, the motherboard should have the letters Pb inside a circle with a line through, screen printed on it) so unless you have some experience in soldering with lead free, you'll probably need to do some searching in your area for electronics repair shops (be sure to ask about their experience with lead free soldering). Lead free soldering requires more heat that can cause extensive damage to the substrate if not done properly.
-experience: 22 years electronics manufacturing and repair (3 leading global electronics manufacturers and the U.S. Navy)
stinger704 -
Well written with precise instructions. The pictures included in these instruction for each stage of the process are clear and shoe exactly what needs to be done. What at first seems a bit of a daunting task to an amateur is a relatively easy tasks when equipped with these instructions. Thank you to the author.
David A - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 105
Her zaman: 65,455
