Ana içeriğe geç
Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: adım 1, 2 resimden 1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: adım 1, 2 resimden 2.
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: adım 2, 1 resimden 1.
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: adım 3, 1 resimden 1.
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: adım 4, 2 resimden 1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: adım 4, 2 resimden 2.
    • Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
    • Lift the rear-facing camera module up and away from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Trent Chapman
1.378 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G15
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,439
