Ana içeriğe geç
Samsung Galaxy Tab S2 8.0 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S2 8.0 Battery Replacement, Screen: adım 1, 1 resimden 1.
    • Working on a device that is turned on may yield an electric shock. Make sure your device is turned off before working on it.
    • Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
    • Put an opening pick in the gap created, in between the screen and the panel.
    • Repeat all around device, putting 2 picks on top and bottom, and one on each side.
  3. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 3, 2 resimden 2.
    • Carefully remove the small suction cup from the corner without moving the screen.
    • Place the small suction cup in the center of the screen and lift to remove screen.
    • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
    • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
  4. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 4, 1 resimden 1.
    • Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
    • Carefully lift the plastic opening tool to detach the ribbon from the tablet.
    • Make sure to discharge any static electricity by touching a grounded metal object, like a quarter, before touching the inside of the device.
  5. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 5, 1 resimden 1.
    • The screen is now detached from the rest of the tablet.
  6. Samsung Galaxy Tab S2 8.0 Battery Replacement, Battery: adım 6, 3 resimden 1. Samsung Galaxy Tab S2 8.0 Battery Replacement, Battery: adım 6, 3 resimden 2. Samsung Galaxy Tab S2 8.0 Battery Replacement, Battery: adım 6, 3 resimden 3.
    • Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
    • Lift up and remove the panel of the board using a plastic opening tool.
  7. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the cable that connects the battery and device using the plastic opening tools.
  8. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 8, 2 resimden 1. Samsung Galaxy Tab S2 8.0 Battery Replacement: adım 8, 2 resimden 2.
    • You can now safely remove the battery from the device by lifting it from the paper flap.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Jonathan Wood
1.011 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, Banghart Spring 2017 Cal Poly, Team S17-G1, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G1
5 Üyeler
15 adet Kılavuz yazıldı
15 Yorum
Does the adhesive behind the screen get messed up during opening, or does it stay together enough to re-bond as before?
jaspchew - Yanıt
Humm u’ve just had to remove the back cover the battery is here no need to remove the screen
Thomas Fuentes - Yanıt
OMG thank you I definitely would have followed the instructions you’re absolutely right the back just case clips and comes off fairly easy
Jessica Pickering -
Thank you. OH GOD thank you.
larissap112 -
This isn’t true with this model. You have the Exnyos one. The Qualcomm one does not have a removable back..
JM M -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 101
Her zaman: 25,213
