Ana içeriğe geç
Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screen: adım 1, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screen: adım 1, 2 resimden 2.
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 2, 2 resimden 2.
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 3, 1 resimden 1.
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 5, 1 resimden 1.
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screws: adım 6, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screws: adım 6, 2 resimden 2.
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: adım 7, 3 resimden 3.
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, SIM Card Holder: adım 8, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, SIM Card Holder: adım 8, 2 resimden 2.
    • Locate the SIM card and the memory card holders along the right side of the tablet.
    • Using the precision tweezers, remove the SIM card and memory card holders.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joy Harris
826 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G4, Sullivan Spring 2017 USF Tampa, Team S3-G4, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 761
