Giriş
The battery is essential to the function of your device. Replace the life of your device by following these simple steps.
Neye ihtiyacın var
Heat the iOpeners in a microwave for 1-2 minutes.
Place heated iOpeners on screen edges to heat the adhesive.
Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
Insert the picks to hold the two components apart once a gap is created.
Where can i get one of these screens for the best price. My mother is a retired senior and happened to drop sumthng on her tablet. I wld like to have it repaired as she just bought it for her xmas present a cple months ago. Now we see a new screen is around 300 $ but does anyone know if other screens from older samsung tablets that are also 9.7 “ will work or whr is cheapest place to find one ?
Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
Position the central panel so the battery logo is facing up.
Gently place the larger plastic opening tool under the ZIF connector on the bottom left of the device.
Lift up to detach this connector from the panel.
Gently lift the battery up from one corner using your hands to remove it from the rest of the central panel.
??? Why not just removing the back cover? You don’t need a to remove the screen to change the battery.
13 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Opening the back of the Samsung Galaxy Tab S2 (SM-T813) with a cutter knife e.g. is a LOT easier than removing the front, and you can also take out the battery
Agreed! Use caution per my next comment below.
Very nice and detailed. Most battery replacement videos for this model suggest removing the back cover instead of the screen. Then follow steps 13 onward. Use caution when removing the back cover so flex cable near power and volume button does not get broken (the connect is wedged into the cover). Suggest removing back cover from non-connector side first (the one with the two mini-posts). Right side when looking with rear camera on top. Once this side is loose, gently lift to expose flex cable for button side. Then pop that out of the cover (GENTLY) before lifting the cover the rest of the way off. This flex cable must remain attached to the mother board. If broken, the mother board and screen need to be separated to replace it!
I just changed my battery, by removing the back cover as indicated on several video. I was very careful, but had a problem as the top round fixation would not come off, and the plastic was slightly damaged (not broken). I put back the cover, and had the grey battery icon syndrome ... I did not know about the flex cable near power and volume, but I was apparently gentle enough that it had just detached itself from the back cover. One problem is that I do not know how to attach it again to the back cover. But I am not even sure that is the problem, as it tends to stay in place (given the size of contacts). I know the battery is correctly connected, because it loaded normally, with the green level indicator up to 3%. But the cover was not fully closed (only on the power/volume side) and it stopped when I tried closing fully.
While prising the back cover off, a component on a tiny ribbon next to the mini-post, broke. The tablet is naturally defunct now. Take care with those 'plectrum' openers, they can cause such a breakage.
Do not remove the screen if you’re replacing the battery, much easier to heat up and pry off the back. Plus no chance of damaging your screen.
Joseph Watson - Yanıt
