Giriş
This replacement is extremely fast, but it requires disassembly of other components of the device first. Please see the prerequisite guides.
Neye ihtiyacın var
Heat the iOpeners in a microwave for 1-2 minutes.
Place heated iOpeners on screen edges to heat the adhesive.
Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
Insert the pointed end of the black spudger into the hole located on the right side of the device.
Use the spudger as a lever to remover the SD Card plastic piece from the reader.
Bir başkası bu kılavuzu tamamladı.
