Giriş
Follow this guide to bring the sound back to your headphones by replacing the auxiliary port.
Neye ihtiyacın var
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
This is where the auxiliary port is located.
Remove the black 3mm screw using a PH000 Phillips screwdriver.
Bir başkası bu kılavuzu tamamladı.
