Ana içeriğe geç
Samsung Galaxy TabPro S Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy TabPro S Rear Facing Camera Replacement, Rear Facing Camera: adım 1, 1 resimden 1.
    • Place the device face down on a flat work surface.
  2. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 2, 2 resimden 1. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 2, 2 resimden 2.
    • Heat the iOpener in the microwave for 30 seconds. Then place it on each side for 20 seconds in order to loosen the adhesive sealing on the device.
  3. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 3, 3 resimden 1. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 3, 3 resimden 2. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 3, 3 resimden 3.
    • Using the plastic spudger, open up the back of the device.
  4. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 4, 1 resimden 1.
    • Locate the camera and its corresponding connecting port.
  5. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 5, 3 resimden 1. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 5, 3 resimden 2. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers carefully peel off the sticker.
  6. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 6, 2 resimden 1. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 6, 2 resimden 2.
    • Using the black nylon spudger, flip the top half of the connecting port downward until you hear a click.
  7. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 7, 1 resimden 1.
    • Proceed to lift up the camera out of its resting position.
  8. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 8, 2 resimden 1. Samsung Galaxy TabPro S Rear Facing Camera Replacement: adım 8, 2 resimden 2.
    • Simply pull the camera parallel to the device out of its connecting port.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jyotsna Gone
515 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Sullivan Spring 2017 USF Tampa, Team 1-2, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 1,539
