Ana içeriğe geç
Samsung Galaxy Victory 4G Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Place phone face down. Ensure the side with the display screen is not facing you.
    • Locate battery door and slide open.
    • Remove battery.
  2. Samsung Galaxy Victory 4G Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Motherboard Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove one Phillips 3.93 mm screw from bottom center of the phone.
  5. Samsung Galaxy Victory 4G Motherboard Replacement: adım 5, 3 resimden 1. Samsung Galaxy Victory 4G Motherboard Replacement: adım 5, 3 resimden 2. Samsung Galaxy Victory 4G Motherboard Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Motherboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy Victory 4G Motherboard Replacement: adım 6, 2 resimden 2.
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
    • At this point the motherboard should be completely detached from the rest of the phone.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Zhao
251 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-3, Remmell Fall 2014 USF Tampa, Team 15-3, Remmell Fall 2014 üyesi
USFT-REMMELL-F14S15G3
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 1,638
