Ana içeriğe geç
Samsung Galaxy View Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy View Battery Replacement, Kickstand: adım 1, 1 resimden 1.
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy View Battery Replacement: adım 2, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 2, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 2, 3 resimden 3.
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy View Battery Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy View Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy View Battery Replacement: adım 4, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 4, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 4, 3 resimden 3.
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy View Battery Replacement: adım 5, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 5, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy View Battery Replacement: adım 6, 2 resimden 1. Samsung Galaxy View Battery Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy View Battery Replacement: adım 7, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 7, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 7, 3 resimden 3.
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
Roger Pena
1.141 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G5
4 Üyeler
12 adet Kılavuz yazıldı
29Kılavuz Yorumları
I’m not sure if it’s the battery or the cord
Swheet - Yanıt Paylaş
What size is the battery that fits into the SAMSUNG TAB VIEW?
Ricky Lee Lidel - Yanıt Paylaş
Thank You, Sooo much. This guide is a true money and time saver. Worked like a gem .
Mike Rowe - Yanıt Paylaş
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Sue ELLEN R FONTENOT - Yanıt Paylaş
Where can I find battery replacement for galaxy view
Greg Dover - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 22
Son 30 gün: 80
Her zaman: 27,829
