Ana içeriğe geç
Samsung Galaxy View Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy View Camera Replacement, Kickstand: adım 1, 1 resimden 1.
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Camera Replacement: adım 2, 3 resimden 1. Samsung Galaxy View Camera Replacement: adım 2, 3 resimden 2. Samsung Galaxy View Camera Replacement: adım 2, 3 resimden 3.
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Camera Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy View Camera Replacement, Battery: adım 3, 2 resimden 2.
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy View Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy View Camera Replacement: adım 4, 3 resimden 3.
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Camera Replacement: adım 5, 3 resimden 1. Samsung Galaxy View Camera Replacement: adım 5, 3 resimden 2. Samsung Galaxy View Camera Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Camera Replacement: adım 6, 2 resimden 1. Samsung Galaxy View Camera Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Camera Replacement: adım 7, 3 resimden 1. Samsung Galaxy View Camera Replacement: adım 7, 3 resimden 2. Samsung Galaxy View Camera Replacement: adım 7, 3 resimden 3.
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Camera Replacement, Camera: adım 8, 3 resimden 1. Samsung Galaxy View Camera Replacement, Camera: adım 8, 3 resimden 2. Samsung Galaxy View Camera Replacement, Camera: adım 8, 3 resimden 3.
    • Place the plastic opening tool underneath the blue press-fit connector which is touching the green circuit board at the bottom of the device.
    • Pry upwards with the plastic opening tool to disconnect the press-fit connector.
    • Remove the camera by carefully gripping the press-fit connector and pulling upwards.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan Thayer
527 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G5
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,018
