Ana içeriğe geç
Samsung Galaxy View Motherboard Replacement
Neye ihtiyacın var
    1. Samsung Galaxy View Motherboard Replacement, Kickstand: adım 1, 1 resimden 1.
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy View Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy View Motherboard Replacement: adım 2, 3 resimden 3.
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy View Motherboard Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy View Motherboard Replacement, Battery: adım 3, 2 resimden 2.
      • Check the device is completely turned off.
      • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy View Motherboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy View Motherboard Replacement: adım 4, 3 resimden 3.
      • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy View Motherboard Replacement: adım 5, 3 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 5, 3 resimden 2. Samsung Galaxy View Motherboard Replacement: adım 5, 3 resimden 3.
      • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
      • Insert the metal spudger within the opening.
      • Move the metal spudger down the seam, prying the back panel open as you go.
      • Once a large enough opening is made, pry the entire back panel off with your hand.
      • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy View Motherboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 6, 2 resimden 2.
      • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy View Motherboard Replacement: adım 7, 3 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 7, 3 resimden 2. Samsung Galaxy View Motherboard Replacement: adım 7, 3 resimden 3.
      • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
      • Remove the battery from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy View Motherboard Replacement, Speakers: adım 8, 3 resimden 1. Samsung Galaxy View Motherboard Replacement, Speakers: adım 8, 3 resimden 2. Samsung Galaxy View Motherboard Replacement, Speakers: adım 8, 3 resimden 3.
      • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
      • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy View Motherboard Replacement: adım 9, 2 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 9, 2 resimden 2.
      • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
      • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy View Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. Samsung Galaxy View Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
      • Insert the plastic opening tool beneath the orange press-fit connector attached to the bottom left side of the motherboard and use a leverage motion to pry the connector from the board.
      • Repeat the above step for the other two orange press-fit connectors attached on the bottom left side of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy View Motherboard Replacement: adım 11, 2 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 11, 2 resimden 2.
      • Use the plastic opening tool to pry up on the blue antenna cable connector near the right edge of the motherboard.
      • Repeat the above for the black antenna cable connector positioned next to the blue wire.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy View Motherboard Replacement: adım 12, 3 resimden 1. Samsung Galaxy View Motherboard Replacement: adım 12, 3 resimden 2. Samsung Galaxy View Motherboard Replacement: adım 12, 3 resimden 3.
      • Use a Phillips #00 screwdriver to remove the nine 3 mm screws around the motherboard.
      • There is a metal bracket beneath four of the screws on the right side of motherboard. This bracket will also be removed during this step.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy View Motherboard Replacement: adım 13, 1 resimden 1.
      • Lift the motherboard straight up to remove it from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Amberley Powell
790 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G5
4 Üyeler
12 adet Kılavuz yazıldı
7Kılavuz Yorumları
Hi… Where can I get a replacement motherboard for a Samsung galaxy view? I need one.
Ryan Mitchell - Yanıt Paylaş
DITTO that I need a new mother board as well. Where can we purchase it?
Lori Marr - Yanıt Paylaş
Hello I need the charger plugin and wire harness replacement parts. there tiny heres a screen shot of what is needed. If anyone knows where please posts info in reply thank you
[img]https://i.imgur.com/QMgrXkh.jpg[/img]
wildcar - Yanıt Paylaş
where can you find a replacement motherboard. seems like all you can you is buy a used one off ebay.
chiming tse - Yanıt Paylaş
where can you buy a replacement motherboard. seems like only way is to buy a used unit off ebay.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 46
Her zaman: 7,906
