Ana içeriğe geç
Samsung Galaxy Xcover GT-S5690 LCD Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Xcover GT-S5690 LCD Replacement, LCD: adım 1, 1 resimden 1.
    • Here is the Samsung Galaxy Xcover, with the LCD broken, that will be replaced.
  2. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 2, 1 resimden 1.
    • The first step, is remove the battery door. It comes with a security lock, that has to be on open position. Start opening from bottom, and releasing from the side edges.
  3. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 3, 2 resimden 1. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 3, 2 resimden 2.
    • Remove with a flat screwdriver, the volume button and the power button
    • Now, with a Phillpis Screwdriver, remove all the screws from the backcover.
    not easy at all
    Jack Chauhan - Yanıt
  4. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 4, 2 resimden 1. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 4, 2 resimden 2.
    • With a flat screwdriver or plastic opener, separate the front case from the rear case. It will be easy!
    was not easy at all. many thanks. PC World
  5. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 5, 3 resimden 1. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 5, 3 resimden 2. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 5, 3 resimden 3.
    • Remove the screw on the lower zone of the main board. The screw is the same of the case, so dont worry if you mix them.
    • Now, with a pliers, unplug the camera and the front speaker. Now, we are going to lift the main board, but ...
    • be careful, below is the LCD flex cable!
  6. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 6, 2 resimden 1. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 6, 2 resimden 2.
    • Remove the LCD flat cable, and then, remove the 2 screws on the sides of the front cover. They are the same as the others screws...
    • Now, you can take apart the chassis from the front cover, leaving only the display and the touch.
  7. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 7, 2 resimden 1. Samsung Galaxy Xcover GT-S5690 LCD Replacement: adım 7, 2 resimden 2.
    • Lift up the black retainer, and take off the touch flex cable.
    • Be careful, the flex has double side tape below the IC.
    • Now, with a knife or cutter, lift carefully the LCD unit. Place the new LCD, and reassembly the phone.
    • In the near future, I´ll post how to replace the touch screen!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jaime
3.333 İtibar
4 adet Kılavuz yazıldı
Bir Yorum
Good and clear. Pics are much better than movie, thank you very much!
pierrequivoyage - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 6,759
