Ana içeriğe geç
Samsung Galaxy Y LCD Display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Y LCD Display Replacement, Back Panel: adım 1, 3 resimden 1. Samsung Galaxy Y LCD Display Replacement, Back Panel: adım 1, 3 resimden 2. Samsung Galaxy Y LCD Display Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y LCD Display Replacement, LCD Display: adım 2, 3 resimden 1. Samsung Galaxy Y LCD Display Replacement, LCD Display: adım 2, 3 resimden 2. Samsung Galaxy Y LCD Display Replacement, LCD Display: adım 2, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y LCD Display Replacement: adım 3, 2 resimden 1. Samsung Galaxy Y LCD Display Replacement: adım 3, 2 resimden 2.
    • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
  4. Samsung Galaxy Y LCD Display Replacement: adım 4, 3 resimden 1. Samsung Galaxy Y LCD Display Replacement: adım 4, 3 resimden 2. Samsung Galaxy Y LCD Display Replacement: adım 4, 3 resimden 3.
    • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
  5. Samsung Galaxy Y LCD Display Replacement: adım 5, 2 resimden 1. Samsung Galaxy Y LCD Display Replacement: adım 5, 2 resimden 2.
    • Gently remove the LCD screen lens from the outer screen using a pair of tweezers and the metal pry tool. Replace the faulty LCD.
    • The LCD maybe be glued in place, so the device might need to be heated to remove the part.
Sonuç
Aidan Kurz
411 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 535
