Ana içeriğe geç
Samsung Galaxy Y s5360 Home Button Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: adım 1, 3 resimden 1. Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: adım 1, 3 resimden 2. Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: adım 2, 3 resimden 1. Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: adım 2, 3 resimden 2. Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: adım 2, 3 resimden 3.
    • Use the screwdriver with a Phillips #000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y s5360 Home Button Replacement: adım 3, 3 resimden 1. Samsung Galaxy Y s5360 Home Button Replacement: adım 3, 3 resimden 2. Samsung Galaxy Y s5360 Home Button Replacement: adım 3, 3 resimden 3.
    • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
    • Using a metal spudger may cause further damage to your device.
  4. Samsung Galaxy Y s5360 Home Button Replacement: adım 4, 3 resimden 1. Samsung Galaxy Y s5360 Home Button Replacement: adım 4, 3 resimden 2. Samsung Galaxy Y s5360 Home Button Replacement: adım 4, 3 resimden 3.
    • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
  5. Samsung Galaxy Y s5360 Home Button Replacement, Home Button: adım 5, 2 resimden 1. Samsung Galaxy Y s5360 Home Button Replacement, Home Button: adım 5, 2 resimden 2.
    • Remove the Home Button from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 1,123
