Giriş
If your display is failing, has distorted color problems, or is cracked, and you'd like to replace it then follow these step by step instructions. This requires close attention of the display and can be somewhat difficult with a rating of 5 out of 10 but should only take about 15 minutes or less if instructions are followed properly. Be careful because it'e possible to damage the case, and display.
Neye ihtiyacın var
Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
5 farklı kişi bu kılavuzu tamamladı.
