Ana içeriğe geç
Samsung Gear 2 Neo Speaker Replacement
Neye ihtiyacın var
  1. Samsung Gear 2 Neo Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Samsung Gear 2 Neo Speaker Replacement: adım 2, 2 resimden 1. Samsung Gear 2 Neo Speaker Replacement: adım 2, 2 resimden 2.
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Samsung Gear 2 Neo Speaker Replacement: adım 3, 1 resimden 1.
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Samsung Gear 2 Neo Speaker Replacement: adım 4, 2 resimden 1. Samsung Gear 2 Neo Speaker Replacement: adım 4, 2 resimden 2.
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
  5. Samsung Gear 2 Neo Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Use a pair of tweezers to remove the rubber gasket. It should come off with ease.
  6. Samsung Gear 2 Neo Speaker Replacement: adım 6, 1 resimden 1.
    • Using the fine tweezers, pull up on the speaker ribbon cable until separated from the back cover. Make sure to approach it like in the picture otherwise it may not come off cleanly.
    • To lift out the speaker, place the tweezers underneath the speaker at the top left corner of the speaker and pry it up.
Sonuç
Victor Yore
705 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-6, Blackwell Fall 2015 USF Tampa, Team 5-6, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S5G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 992
