Ana içeriğe geç
Samsung Gear 360 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Gear 360 Motherboard Replacement, Case: adım 1, 3 resimden 1. Samsung Gear 360 Motherboard Replacement, Case: adım 1, 3 resimden 2. Samsung Gear 360 Motherboard Replacement, Case: adım 1, 3 resimden 3.
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Motherboard Replacement: adım 2, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 2, 2 resimden 2.
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Motherboard Replacement: adım 3, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 3, 2 resimden 2.
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Motherboard Replacement: adım 4, 3 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 4, 3 resimden 2. Samsung Gear 360 Motherboard Replacement: adım 4, 3 resimden 3.
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Motherboard Replacement: adım 5, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 5, 2 resimden 2.
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Motherboard Replacement: adım 6, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Motherboard Replacement: adım 7, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 7, 2 resimden 2.
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Motherboard Replacement: adım 8, 3 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 8, 3 resimden 2. Samsung Gear 360 Motherboard Replacement: adım 8, 3 resimden 3.
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Motherboard Replacement: adım 9, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 9, 2 resimden 2.
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Motherboard Replacement: adım 10, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Motherboard Replacement: adım 11, 3 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 11, 3 resimden 2. Samsung Gear 360 Motherboard Replacement: adım 11, 3 resimden 3.
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Motherboard Replacement: adım 12, 2 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 12, 2 resimden 2.
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Motherboard Replacement: adım 13, 3 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 13, 3 resimden 2. Samsung Gear 360 Motherboard Replacement: adım 13, 3 resimden 3.
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Motherboard Replacement, Motherboard: adım 14, 2 resimden 1. Samsung Gear 360 Motherboard Replacement, Motherboard: adım 14, 2 resimden 2.
    • Use a plastic opening tool to disconnect the sensors from the motherboard to free it.
  15. Samsung Gear 360 Motherboard Replacement: adım 15, 1 resimden 1.
    • Using a PH000 Screwdriver head, unscrew the Phillips #000 0.5 mm screw connected to the motherboard.
  16. Samsung Gear 360 Motherboard Replacement: adım 16, 3 resimden 1. Samsung Gear 360 Motherboard Replacement: adım 16, 3 resimden 2. Samsung Gear 360 Motherboard Replacement: adım 16, 3 resimden 3.
    • To remove the motherboard from the device, use a plastic opening tool on the edges and lift up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Connor
454 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Sullivan Spring 2017 USF Tampa, Team S3-G5, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G5
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
What is the part number of the motherboard? Mine is stuck in firmware upgrade state and Samsung won't even look at it.
So maybe a motherboard replacement is the easiest answer.
Thanks
Hane Hormes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,355
