Giriş
Use this guide to remove the motherboard from the Samsung Gear 360. You will have to complete a full tear-down of the device to get to the motherboard, so follow the directions carefully and take your time to ensure you complete every step correctly.
Neye ihtiyacın var
Use a plastic opening tool to disconnect the sensors from the motherboard to free it.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
What is the part number of the motherboard? Mine is stuck in firmware upgrade state and Samsung won't even look at it.
So maybe a motherboard replacement is the easiest answer.
Thanks
