Ana içeriğe geç
Samsung Gear 360 Rear Camera Replacement
Neye ihtiyacın var
  1. Samsung Gear 360 Rear Camera Replacement, Case: adım 1, 3 resimden 1. Samsung Gear 360 Rear Camera Replacement, Case: adım 1, 3 resimden 2. Samsung Gear 360 Rear Camera Replacement, Case: adım 1, 3 resimden 3.
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Rear Camera Replacement: adım 2, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 2, 2 resimden 2.
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Rear Camera Replacement: adım 3, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 3, 2 resimden 2.
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Rear Camera Replacement: adım 4, 3 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 4, 3 resimden 2. Samsung Gear 360 Rear Camera Replacement: adım 4, 3 resimden 3.
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Rear Camera Replacement: adım 5, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 5, 2 resimden 2.
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Rear Camera Replacement: adım 6, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Rear Camera Replacement: adım 7, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 7, 2 resimden 2.
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Rear Camera Replacement: adım 8, 3 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 8, 3 resimden 2. Samsung Gear 360 Rear Camera Replacement: adım 8, 3 resimden 3.
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Rear Camera Replacement: adım 9, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 9, 2 resimden 2.
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Rear Camera Replacement: adım 10, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 10, 2 resimden 2.
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Rear Camera Replacement: adım 11, 3 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 11, 3 resimden 2. Samsung Gear 360 Rear Camera Replacement: adım 11, 3 resimden 3.
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Rear Camera Replacement: adım 12, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 12, 2 resimden 2.
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Rear Camera Replacement: adım 13, 3 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 13, 3 resimden 2. Samsung Gear 360 Rear Camera Replacement: adım 13, 3 resimden 3.
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Rear Camera Replacement, Rear Camera: adım 14, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement, Rear Camera: adım 14, 2 resimden 2.
    • Within the grey half of the case, unscrew both Phillips #00 0.75 mm screws located on the metal plate using PH00 screwdriver.
  15. Samsung Gear 360 Rear Camera Replacement: adım 15, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 15, 2 resimden 2.
    • Once the screws have been removed, remove the metal plate.
  16. Samsung Gear 360 Rear Camera Replacement: adım 16, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 16, 2 resimden 2.
    • Using a PH000 screwdriver head, remove the both Phillips #000 0.75 mm screws on the grey case.
  17. Samsung Gear 360 Rear Camera Replacement: adım 17, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 17, 2 resimden 2.
    • Using a plastic opening tool, remove the plastic cover underneath the rear camera
  18. Samsung Gear 360 Rear Camera Replacement: adım 18, 2 resimden 1. Samsung Gear 360 Rear Camera Replacement: adım 18, 2 resimden 2.
    • Gently remove the rear camera module by using a plastic opening tool and lifting the module.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Connor
454 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Sullivan Spring 2017 USF Tampa, Team S3-G5, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G5
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
number datasheet sensor camera?
Pelicula 360 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,403
