Ana içeriğe geç
Samsung Gear Fit Screen Replacement
Neye ihtiyacın var
  1. Samsung Gear Fit Screen Replacement, Watch Band: adım 1, 2 resimden 1. Samsung Gear Fit Screen Replacement, Watch Band: adım 1, 2 resimden 2.
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Gear Fit Screen Replacement, Screen: adım 2, 1 resimden 1.
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Gear Fit Screen Replacement: adım 3, 3 resimden 1. Samsung Gear Fit Screen Replacement: adım 3, 3 resimden 2. Samsung Gear Fit Screen Replacement: adım 3, 3 resimden 3.
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Gear Fit Screen Replacement: adım 4, 3 resimden 1. Samsung Gear Fit Screen Replacement: adım 4, 3 resimden 2. Samsung Gear Fit Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Gear Fit Screen Replacement: adım 5, 3 resimden 1. Samsung Gear Fit Screen Replacement: adım 5, 3 resimden 2. Samsung Gear Fit Screen Replacement: adım 5, 3 resimden 3.
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Gear Fit Screen Replacement: adım 6, 2 resimden 1. Samsung Gear Fit Screen Replacement: adım 6, 2 resimden 2.
    • Gently peel the screen assembly up and away from the device using tweezers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Nathan Powell
1.584 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-49, Amido Spring 2014 Cal Poly, Team 11-49, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G49
4 Üyeler
4 adet Kılavuz yazıldı
28Kılavuz Yorumları
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Yanıt Paylaş
Where can you buy replacement screen?
Yele Olaniyi - Yanıt Paylaş
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Yanıt Paylaş
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Yanıt Paylaş
Does anyone know where to get the replacement screen?
MrGratts - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 54,666
