Ana içeriğe geç
Samsung Gear Live Battery Replacement
Neye ihtiyacın var
    1. Samsung Gear Live Battery Replacement, Lay the watch face-down: adım 1, 1 resimden 1.
      • Lay the watch face-down on a flat, stable surface.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear Live Battery Replacement, Remove the holding pin: adım 2, 1 resimden 1.
      • Press the watchband down against the work surface.
      • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear Live Battery Replacement, Remove the watchband: adım 3, 1 resimden 1.
      • With the spring-loaded pin pressed in, the watch band should release easily.
      • Gently pull the band away from the body of the watch.
      • Repeat steps 2 and 3 for the opposite side.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Gear Live Battery Replacement, Locate the four screws: adım 4, 1 resimden 1.
      • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear Live Battery Replacement, Remove the 4 screws: adım 5, 1 resimden 1.
      • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear Live Battery Replacement, Pry off the back of the watch.: adım 6, 1 resimden 1.
      • Gently work the plastic opening tool under the top edge of the watch’s back cover.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Gear Live Battery Replacement, Lift off the back cover: adım 7, 2 resimden 1. Samsung Gear Live Battery Replacement, Lift off the back cover: adım 7, 2 resimden 2.
      • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Gear Live Battery Replacement, Set both halves of the watch aside: adım 8, 1 resimden 1.
      • Lay both halves of the watch body assembly face down (with internal components facing up).
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Gear Live Battery Replacement, Locate the battery: adım 9, 1 resimden 1.
      • Locate the battery on the back half of the disassembled watch body. It is rectangular in shape and located just above the window for the heart monitor.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear Live Battery Replacement, Locate the battery contacts: adım 10, 1 resimden 1.
      • Locate the battery’s electrical contacts. They are located next to the heart rate monitor. They roughly form a “+” shape.
      • Using the plastic opening tool, gently pry the contacts away from the plastic channel in which they fit.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear Live Battery Replacement, Pry out the battery: adım 11, 1 resimden 1.
      • Gently work the plastic opening tool under the battery.
      • Using the plastic opening tool, gently pry the battery up.
      • If replacing the battery, please dispose of it properly. Do not throw the battery in the trash. Contact your local municipality for locations which accept lithium-ion batteries for disposal or recycling.
      FixBot'a Sor
      Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Keith Cooper
1.265 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G7
3 Üyeler
7 adet Kılavuz yazıldı
7Kılavuz Yorumları
Indicate the tools needed.
Dan Brown - Yanıt Paylaş
Indicate screw measurements to nearest mm.
This is neat and helpful, but where do I find a replacement battery?
joshthehappy - Yanıt Paylaş
Where can I purchase these batteries?
chad flores - Yanıt Paylaş
I purchased my battery on eBay.
Jay - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 10,101
