Ana içeriğe geç
Samsung Gear Live Heart Rate Monitor Replacement
Neye ihtiyacın var
    1. Samsung Gear Live Heart Rate Monitor Replacement, Lay the watch face-down: adım 1, 1 resimden 1.
      • Lay the watch face-down on a flat, stable surface.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear Live Heart Rate Monitor Replacement, Remove the holding pin: adım 2, 1 resimden 1.
      • Press the watchband down against the work surface.
      • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear Live Heart Rate Monitor Replacement, Remove the watchband: adım 3, 1 resimden 1.
      • With the spring-loaded pin pressed in, the watch band should release easily.
      • Gently pull the band away from the body of the watch.
      • Repeat steps 2 and 3 for the opposite side.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Gear Live Heart Rate Monitor Replacement, Locate the four screws: adım 4, 1 resimden 1.
      • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear Live Heart Rate Monitor Replacement, Remove the 4 screws: adım 5, 1 resimden 1.
      • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear Live Heart Rate Monitor Replacement, Pry off the back of the watch.: adım 6, 1 resimden 1.
      • Gently work the plastic opening tool under the top edge of the watch’s back cover.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: adım 7, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: adım 7, 2 resimden 2.
      • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Gear Live Heart Rate Monitor Replacement, Set both halves of the watch aside: adım 8, 1 resimden 1.
      • Lay both halves of the watch body assembly face down (with internal components facing up).
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: adım 9, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: adım 9, 2 resimden 2.
      • Locate the ribbon cable connector near the edge of the watch's case.
      • Using the plastic opening tool, gently pry the connector from the motherboard
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: adım 10, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: adım 10, 2 resimden 2.
      • Using the plastic opening tool, gently pry away the red spacers.
      • Set the spacers aside.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: adım 11, 3 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: adım 11, 3 resimden 2. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: adım 11, 3 resimden 3.
      • Insert the end of the plastic opening tool under the motherboard.
      • Gently pry up the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: adım 12, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: adım 12, 2 resimden 2.
      • Set the motherboard on a flat, stable surface.
      • Using the plastic opening tool, gently pry the heart rate sensor cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: adım 13, 3 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: adım 13, 3 resimden 2. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: adım 13, 3 resimden 3.
      • Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Keith Cooper
1.265 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G7
3 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Check all of your guides to make sure you've indicate the needed tools.
Dan Brown - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 2,093
