Ana içeriğe geç
Samsung Gear Live Heart Rate Monitor Replacement
Neye ihtiyacın var
  1. Samsung Gear Live Heart Rate Monitor Replacement, Lay the watch face-down: adım 1, 1 resimden 1.
    • Lay the watch face-down on a flat, stable surface.
    Be sure to proofread carefully.
    Dan Brown - Yanıt
  2. Samsung Gear Live Heart Rate Monitor Replacement, Remove the holding pin: adım 2, 1 resimden 1.
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Heart Rate Monitor Replacement, Remove the watchband: adım 3, 1 resimden 1.
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
  4. Samsung Gear Live Heart Rate Monitor Replacement, Locate the four screws: adım 4, 1 resimden 1.
    • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
  5. Samsung Gear Live Heart Rate Monitor Replacement, Remove the 4 screws: adım 5, 1 resimden 1.
    • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
  6. Samsung Gear Live Heart Rate Monitor Replacement, Pry off the back of the watch.: adım 6, 1 resimden 1.
    • Gently work the plastic opening tool under the top edge of the watch’s back cover.
  7. Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: adım 7, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: adım 7, 2 resimden 2.
    • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
    Good action shots here!
    Dan Brown - Yanıt
  8. Samsung Gear Live Heart Rate Monitor Replacement, Set both halves of the watch aside: adım 8, 1 resimden 1.
    • Lay both halves of the watch body assembly face down (with internal components facing up).
  9. Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: adım 9, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: adım 9, 2 resimden 2.
    • Locate the ribbon cable connector near the edge of the watch's case.
    • Using the plastic opening tool, gently pry the connector from the motherboard
    You forgot the second ribbon for the vibrator motor.
    Rebecca Montgomery - Yanıt
  10. Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: adım 10, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: adım 10, 2 resimden 2.
    • Using the plastic opening tool, gently pry away the red spacers.
    • Set the spacers aside.
  11. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: adım 11, 3 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: adım 11, 3 resimden 2. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: adım 11, 3 resimden 3.
    • Insert the end of the plastic opening tool under the motherboard.
    • Gently pry up the motherboard.
  12. Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: adım 12, 2 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: adım 12, 2 resimden 2.
    • Set the motherboard on a flat, stable surface.
    • Using the plastic opening tool, gently pry the heart rate sensor cable from the motherboard.
  13. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: adım 13, 3 resimden 1. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: adım 13, 3 resimden 2. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: adım 13, 3 resimden 3.
    • Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Keith Cooper
1.241 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G7
3 Üyeler
Bir Yorum
Check all of your guides to make sure you've indicate the needed tools.
Dan Brown - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,559
