Ana içeriğe geç
Samsung Gear S Display Assembly Replacement
Neye ihtiyacın var
    1. Samsung Gear S Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 1. Samsung Gear S Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 2. Samsung Gear S Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 3.
      • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear S Display Assembly Replacement: adım 2, 2 resimden 1. Samsung Gear S Display Assembly Replacement: adım 2, 2 resimden 2.
      • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
      • Some force is needed due to adhesive seal.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear S Display Assembly Replacement: adım 3, 1 resimden 1.
      • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Gear S Display Assembly Replacement: adım 4, 1 resimden 1.
      • Locate the ribbon assembly attaching the display to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Gear S Display Assembly Replacement: adım 5, 1 resimden 1.
      • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Gear S Display Assembly Replacement: adım 6, 1 resimden 1.
      • Now the watch should be in three separate pieces.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
19 farklı kişi bu kılavuzu tamamladı.
Ekip
USF Tampa, Team 12-1, Blackwell Fall 2015 USF Tampa, Team 12-1, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G1
4 Üyeler
5 adet Kılavuz yazıldı
16Kılavuz Yorumları
Where can i get the LCD for Gear S
Kuek See Chuan - Yanıt Paylaş
my screen flashing light and show on screen lines
avi mor - Yanıt Paylaş
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
Mark Measures - Yanıt Paylaş
My watch is doing the same thing. Did you get a fix for it?
steve Walks - Yanıt Paylaş
There are flashing yellow lights on the screen, could I fix that?
Alex - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 16,307
