Ana içeriğe geç
Samsung Gear S2 Battery Replacement
Neye ihtiyacın var
  1. Samsung Gear S2 Battery Replacement, Watch Strap: adım 1, 2 resimden 1. Samsung Gear S2 Battery Replacement, Watch Strap: adım 1, 2 resimden 2.
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Battery Replacement: adım 2, 2 resimden 1. Samsung Gear S2 Battery Replacement: adım 2, 2 resimden 2.
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Battery Replacement: adım 3, 2 resimden 1. Samsung Gear S2 Battery Replacement: adım 3, 2 resimden 2.
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Battery Replacement, Back: adım 4, 2 resimden 1. Samsung Gear S2 Battery Replacement, Back: adım 4, 2 resimden 2.
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Battery Replacement, Motherboard: adım 5, 2 resimden 1. Samsung Gear S2 Battery Replacement, Motherboard: adım 5, 2 resimden 2.
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Battery Replacement: adım 6, 3 resimden 1. Samsung Gear S2 Battery Replacement: adım 6, 3 resimden 2. Samsung Gear S2 Battery Replacement: adım 6, 3 resimden 3.
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Battery Replacement: adım 7, 2 resimden 1. Samsung Gear S2 Battery Replacement: adım 7, 2 resimden 2.
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
  8. Samsung Gear S2 Battery Replacement, Battery: adım 8, 2 resimden 1. Samsung Gear S2 Battery Replacement, Battery: adım 8, 2 resimden 2.
    • Using tweezers, lift the battery casing.
    • Make sure the cables are fed through their gaps to avoid damaging them.
  9. Samsung Gear S2 Battery Replacement: adım 9, 2 resimden 1. Samsung Gear S2 Battery Replacement: adım 9, 2 resimden 2.
    • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
    • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
Sonuç
100 farklı kişi bu kılavuzu tamamladı.
Jacob Baldwin
3.412 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S2G3
3 Üyeler
23 adet Kılavuz yazıldı
39 Yorum
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - Yanıt
A reference to the battery part number would be great.
Harold Turner - Yanıt
Very good job and very easy
JEAN PIERRE - Yanıt
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 128
Son 30 gün: 526
Her zaman: 153,389
