Giriş
Has the buckle on the strap of your watch become broken, or do you just want to replace the factory strap with a custom one? Just swap it out.
Neye ihtiyacın var
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Using your finger, push forward on the release while pulling up on the strap.
The bracelet should be removed first!
Das Armband sollte zuerst entfernt werden!
7 farklı kişi bu kılavuzu tamamladı.
6 Yorum
can you also provide instruction to change home button on Gear S2
thanks
Where can you buy new straps?
Ebay Amazon etc.
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
The warning to turn off the watch to avoid electrical shock was a joke, right?!
nanev - Yanıt
The screws don't seem to be turning easily. What's the best way to loosen them without stripping them?
Mark Franz - Yanıt
I’m going to be shocked by a dead 3.8V battery? Of course, only if the watch is powered on. Ridiculous statements like this do not reflect positively on the credibility of this entire procedure. If the author seriously thinks this is a danger then I question your basic understanding of electronics.
Alex Tatistcheff - Yanıt
… to avoid being shocked when you lose your data! :)
Reuben Janzen-Martin - Yanıt
