Ana içeriğe geç
Samsung Gear S3 Frontier Bezel Ring Replacement
Neye ihtiyacın var
  1. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: adım 1, 3 resimden 1. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: adım 1, 3 resimden 2. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: adım 1, 3 resimden 3.
    • Contains small springs and ball bearings. We suggest working over a plate or tray.
    • Hold the watch firmly in one hand, face up.
    • Place the iFixit Opening Tool under the bezel ring and use prying motion to remove.
    • The plastic retainer is manufactured with an open gap, you did not break it.
    • For reassembly, set the plastic retainer in the ring, then press the ring down until it snaps in place.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Mark Iknoian
1.033 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S15G2
4 Üyeler
34 adet Kılavuz yazıldı
42 Yorum
I got the bezel popped off to clean it. Now it wont pop back on! Help!
shileski - Yanıt
line up the bezel with the screen and push it in
Arthur -
I’ve tried lining it up with the screen and pushing it in about 50 times now and everytime I do it clicks, but after rotating it a few times the bezel locks and I can’t rotate it anymore. YES all the ball bearings are in the right place, YES the springs are in the right place. There’s this little plastic piece that I can’t tell if it goes inside the bezel piece or if it goes on top of the watch next to the ball bearings. I’m able to get the bezel back on when I put the little plastic piece on the bezel, it clicks right in, but it locks up. When I leave the little plastic piece on the watch I can’t get it to click in at all. I think I just royally f’ed up my watch!
Hardy T - Yanıt
did u manage to fix it?
Dave Green - Yanıt
Interested to know if anyone had much success with this process.
Seth Armour - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 96
Son 30 gün: 396
Her zaman: 86,974
