Ana içeriğe geç
Samsung Gear S3 Frontier Front Screen Assembly Replacement
Neye ihtiyacın var
    1. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Back Cover: adım 1, 1 resimden 1.
      • Place the watch screen-down so that its back cover is showing.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 2, 2 resimden 1. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 2, 2 resimden 2.
      • Remove the four 4.2mm screws with a Y00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 3, 3 resimden 1. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 3, 3 resimden 2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 3, 3 resimden 3.
      • This step will ruin the water-proof seal.
      • Wedge the metal spudger in between the back cover and the frame along the seam.
      • Use force to pry the back cover away from the main watch frame.
      • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: adım 4, 3 resimden 1. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: adım 4, 3 resimden 2. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: adım 4, 3 resimden 3.
      • Detach the three connectors on the motherboard using your fingernail.
      • The connectors are easy to pop off. Minimal force is necessary.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 5, 3 resimden 1. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 5, 3 resimden 2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: adım 5, 3 resimden 3.
      • Separate the motherboard and front screen assembly using a spudger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Jimmy Algeo
880 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S15G2
4 Üyeler
34 adet Kılavuz yazıldı
9Kılavuz Yorumları
can you tell me where can i buy the whole front screen  ?
Ahmad Hariki - Yanıt Paylaş
Jerzy Jerzyk - Yanıt Paylaş
Same question, I am having great difficulty in locating the PARTS to complete these repairs. Can someone please list where we can actually purchase the replacement parts that are shown in these guides??
ArcadeDude44 - Yanıt Paylaş
Can anyone please tell, where to get the parts?
Sunny Tate - Yanıt Paylaş
Eleazar Lagundino - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 84
Her zaman: 22,959
