Giriş
Is your wristband damaged or do you want to change it for a new one? If so, follow this this replacement guide to learn how to do so.
Videoya Genel Bakış
Place the watch screen-down so that its back cover is showing.
Use your nail to push the small silver ball bearing on the right side downward.
While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
2 farklı kişi bu kılavuzu tamamladı.
