Ana içeriğe geç
Samsung Gear S3 Frontier Wristband Replacement
Videoya Genel Bakış
  1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: adım 1, 3 resimden 1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: adım 1, 3 resimden 2. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: adım 1, 3 resimden 3.
    • Place the watch screen-down so that its back cover is showing.
    • Use your nail to push the small silver ball bearing on the right side downward.
    • If your nails aren't sharp enough, you can use a sharp pointed object such as a toothpick or pen.
    • While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
    • For reassembly, hold the ball down and then wedge each pin on the wristband into the pin holes of the main frame.
    • Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Corey Rumbaugh
1.507 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S15G2
4 Üyeler
34 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 2,809
